Previous in Forum: What is the Stack Crack ?   Next in Forum: BIL & SIL of 345kV System w.r.t ANSI
Transformers in Series
08/20/2010 3:47 PM
Hello everyone,
I have a scenario: I have an equipment rated 120V. It uses a stepdown (120/24V) transformer to generate a 24V AC that is later rectified to 24V DC. Total load is rated 65W. However, I have only a 240V supply available. I am unable to replace the step down transformer with one for 240/24V. So I decided to install another step down transformer for 240/120V (which can supply a maximum load of 100W) whose 120V output is the input to the 120/24V transformer.
Please help me figure out the total load. Will it be (65W+losses for the new trnsfrmr), or it is something like (65+65=130W!!)?
What is the correct (or closest approximation) total system load? ie. what is the total power consumption for transformers in series?
Never stop asking questions.
Re: Transformers in series
08/20/2010 4:43 PM
65W+losses for the new trnsfrmr...
Next!
08/21/2010 4:17 AM
Hi, Thanks for that.
Now,to make it more interesting: if the 120/24V transformer can operate at 65 W maximum, does that mean I am wasting (unusable) 35W capacity by using a 100W 240/120V transformer?
08/21/2010 4:39 AM
You seem to be under the impression that you are entertaining us.
Not so...
The Power rating of a transformer is the amount of power it can deliver, not the ammount it consumes, it's as simple as that.
You could drive your Ipod from a 10w transformer in series with a 25w transformer, in series with a 50w transformer, in series with a 100w transformer, in series with a 100MW hyrdo electric plant, it would alter the amout of power the Ipod consumed.
OK you'd looses a fair bit in quiescent current at each transformer.
If you have a genuine question that isn't homework, then we love to help, or if you have a "challenge question" or puzzle, fine, but let us know what it is.
08/21/2010 5:34 AM
Hi there,
Thanks for the prompt replies.
Sorry about my choice of words, if it was a bit flowery. I just wanted to explore a new possibility, not practically do it! It is neither a challenge, puzzle or homework, just ideas and shared thoughts. Thanks
08/21/2010 7:52 AM
Aw ignore me. I just a grumpy old Cat
08/22/2010 3:03 AM
Ha ha ha, got you Del the Cat!
Have a good day.
08/22/2010 3:06 AM
I think not... you'll find we have you...if you look around you'll see the exits are blocked.
You're ours now <cackles wildly>
Register to Reply 7 comments
You might be interested in: Transformers, Power Transformers, Telecom Transformers
