Previous in Forum: Transmission Line Problem   Next in Forum: Pressure Transducer
Energy Consumption
08/22/2010 1:44 AM
What would be energy consumption at same voltage in ac & dc coil.
Good Answers: 181
Re: energy consumption
08/22/2010 4:03 AM
What ever the coil is rated at!
Good Answers: 804
08/22/2010 3:42 PM
Energy is energy. If you have a 2kW load, the energy it will use will be 2kW AC or DC. But consumption is also a factor of load and efficiency. Conversion from one form of electricity flow to the other costs efficiency. If your load is AC and the source is AC, then that will be MUCH higher efficiency than if your load is AC and the source is DC, and vice versa.
So frame your question with specifics, unless this is a homework assignment, in which case do your own work.
Re: Energy Consumption
08/22/2010 9:19 PM
it'll be the power rating of your component either AC/DC multiplied by the time it was used..
take care of your seconds and the minute will take care of itself..
JRaef (1); rockraiden (1); TonyS (1)
