Previous in Forum: vvvf drive   Next in Forum: Mimic Panel
vvvf Drive
08/25/2010 4:59 AM
1) what is active front end drive,and regenerative drives where these drives are used,also regenerative is to be compulsorily of active front end?
Good Answers: 804
Re: vvvf drive
08/25/2010 6:59 AM
Homework for school? Shame shame...
Good Answers: 181
Re: vvvf drive
08/25/2010 7:14 AM
Active front end is where the shaft thingy sticks out of the motor and turns
Regenerative is when shaft thingy sticking out of the motor doesn't want to turn
Compulsory regenerative, buy a generator
Re: vvvf Drive
08/26/2010 9:38 AM
Regeneration is used to recover wasted mechanical energy that would normally be dissipated with brake resistors and convert it into electrical energy. Examples are elevators going from a higher floor to a lower floor, or a crane lowering a load. The easiest and most efficient way to use this wasted energy is to connect the DC bus of multiple drives together which is easy to do for a bank of elevators.
An active front end senses that the DC bus voltage has risen over the nominal input voltage and drives AC current back to the input line (in phase with the utility). The utility power meter is effectively turning backwards when regenerating as you are delivering power to the distribution line.
You might be interested in: DC Motor Drives, AC Motor Drives, Servo Drives
