Previous in Forum: Vehicle Tracking Devices   Next in Forum: FCC CFR Title 47
Surge Suppresors
08/26/2010 8:04 AM
Hello,
Could anyone help with a place I might find some schematics and or insight on surge suppressors (such as polyphasor), such as the type you attach to transmission lines for antennas or power supplies going to tower mounted radios and dishes, I am somwhat perplexed by the fact they pass both dc supplies and ac if and broadcast frequencies as well as squelching high powered lightning voltages without burning out the suppressor(most of the time),at the same time presenting very little resistance and inpedance to the intended frequencies and power supples going through them. Also, a while back there was a string on a site that had collections of different schematics that where available for viewing. If anyone remembers what that site is, it would be greatly appreciated.
thanks
J. Floyd
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
Re: Surge Suppresors
08/26/2010 8:50 AM
Have you seen this article "Modern Coaxial Lightning Arrestors:
Polyphaser Vs. I.C.E.
" I think it might help you out.
http://www.iceradioproducts.com/33.htm
You might also gain some insight from ARRL's 3-part series on "Lightning Protection for the Amateur Radio Station"
part 1: »www.arrl.org/tis/info/pdf/0206056.pdf
part 2: »www.arrl.org/tis/info/pdf/0207048.pdf
part 3: »www.arrl.org/tis/info/pdf/0208053.pdf
AB PLC Training onsite, On-Line, training software and more. BIN95.com
08/26/2010 1:27 PM
Thank you bin95
that does give me a little better idea of what is going on in it
appreciate it
j.floyd
Register to Reply 2 comments
