Previous in Forum: Engineering Management   Next in Forum: A Conversation With Bill Gates
15 comments
CO2 Gas Grades
08/30/2010 9:02 AM
Are there different grades of carbon dioxide gas?
Is the gas used in fizzy drinks the same as gas purchased at a welding supply vendor?
Re: CO2 Gas Grades
08/30/2010 10:22 AM
Which grade gets used in fizzy drinks?
Re: CO2 Gas Grades
08/30/2010 10:32 AM
Don't know. Call these people:
Carbon Dioxide Supplier
Re: CO2 Gas Grades
08/30/2010 11:10 AM
Hi Nat:
I don't know exactly what grade they use, but I assume it is not too critical, since carbonated beverages have been around for a while, even before we started worrying about everything; check HOW they use it (and note the use of nitrogen):
If you want more info go to this site.
Yahlasit
Fans of Old Computers - Commodore 64 - Commodore Vic 20 Australia - Member - New Member
Re: CO2 Gas Grades
08/30/2010 10:48 PM
Though vendors will call it different names (brand names) Food grade gases need to comply with your country's Food Additives Authority.
FDA approvals for the grade and the testing of the of the grade are needed for a gas to be used in or with food for human consumption.
I like deadlines, I like the swooshing sound they make as they fly pass - Douglas Adams
Re: CO2 Gas Grades
08/30/2010 11:17 AM
Its the same stuff. I worked at Praxair for a while and liquid CO2 is the same regardless of what size or style of tank its in.
Some tanks are liquid feed some are vapor feed but thats about all there is for variations in a pure tank of CO2.
Re: CO2 Gas Grades
08/30/2010 11:19 AM
I understand that "food grade" is stored in glass lined tanks and industrial grade is not.
Re: CO2 Gas Grades
08/30/2010 1:31 PM
I have scrapped out a number of food service CO2 tanks and medical gas tanks over the years and used them to make other things and so far I have yet to ever find one that was glass lined.
Maybe some are but from what I have personally seen working in the supply side and from personal experience the vast majority of those tanks are generic use in design.
The only difference I have seen tanks is the paperwork supporting the source and inspection records. Medical grade and food grade gases come in the same tanks as regular welding gases. Its just the paperwork and price thats different.
Re: CO2 Gas Grades
08/30/2010 5:48 PM
Thanks for that. Paperwork! Certs.
Added cost!
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
Re: CO2 Gas Grades
08/31/2010 12:11 AM
I'd go along with that.
Sounds about the same as the aircraft industry.
Same part for non-aircraft duty is considerably cheaper because of nil paper trail.
Had experience with engines.
Cheers,
Stu.
"Nothing, is as it seems." Dr Wally.
Re: CO2 Gas Grades
08/31/2010 1:08 AM
also technical grade, research grade, and laboratory grade. i don't think these came from the same source as welding supply, or food grade, or fire extinguisher supply houses.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
Re: CO2 Gas Grades
08/31/2010 9:54 AM
As others have stated, the food/beverage grade CO2 will come from the same source at the industrial gas supplier but the food grade CO2 will need to pass the additional analysis hurdles for supply. In my experience (CO2 pipeline in Mississippi) the food grade plants take CO2 from the industrial pipeline (used for EOR) and purify the CO2 by removing sulfur, hydrocarbons, moisture, etc. During this process, the CO2 eventually gets liquified and distilled to remove non-condensables and the column bottoms are sent to storage as a liquid for eventual shipping to cylinder fillers or local tank installations.
Money doesn't talk, it screams in your face.
Re: CO2 Gas Grades
08/31/2010 12:46 PM
please ignore my previous post re grades. got mixed up with NACL grades.sorry
Re: CO2 Gas Grades
09/03/2010 6:26 AM
Hello Natfuelbill:
From people I know in the soft drink game, the only difference is the CO2 is purer for use in soft drinks. Sort of like the purity between vetenary medication and human medication.
Cheers Peter
Re: CO2 Gas Grades
09/03/2010 8:34 AM
Thanks all!
Would you give your loved-ones drinks fizzed with CO2 from the welding distributor?
Re: CO2 Gas Grades
09/03/2010 8:59 AM
How about oxygen at the hospital? Or helium for your MRI machine. All the same oat bag.
Register to Reply 15 comments
Anonymous Poster (1); betomachine (2); DaS Energy (1); lyn (3); Natfuelbill (2); ozone88 (1); pretzel (2); Stueywright (1); tcmtech (2)
