Previous in Forum: Nitrogen Generator for Controlled Atmosphere Storage (CAS) Cold Rooms   Next in Forum: Hydrostatic Testing for High Pressure System
Cassette A/C Unit
08/30/2010 12:50 PM
Dear Sir,
I am a working employee, there was continuous frosting of my chilled inlet pipe line and falcieling getting damaged and we are replacing with new falceiling every 3 months and the Cassette units were 4nos in server room, and changing accordingly please suggest, and give me suggestion for permanent solution is there any material to stop the water frosting , we are keeping the Temperature as 22deg cen
Re: Cassette A/C Unit
08/31/2010 1:57 AM
Dear Sir,
Your problem needs more input parameters.
(1) Where are the units located ? Coastal area or very hot climate ?
(2) Why do you need 22 deg ( Cent) ? Any process or other conditions like a
medical lab?
(3) Is the area is highly humid Or the area between false ceiling & the roof
prone to moisture ?
(4) Do you have enough gas volume & pressure ? low gas may lead to frosting.
(5) Is there any way to keep the area ( refer 3 ) dry by having any natural
ventilation or exh.fans ?
(6) Any damaged gas line insulation ? Are the drain lines from the units have
reqd slope Or any drain line choke up ?
I am not an HVAC man but these points are common in any system.
Manroop.Chennai.
09/07/2010 3:04 PM
1) 1) Where are the units located ? Coastal area or very hot climate ? Ans :Tropical (hyderabad hiteccity)
2) Why do you need 22 deg ( Cent) ? Any process or other conditions like a medical lab?Ans :server room
(3) Is the area is highly humid Or the area between false ceiling & the roof prone to moisture ? Ans :no
(4) Do you have enough gas volume & pressure ? low gas may lead to frosting? Ans : having enough gas
(5) Is there any way to keep the area ( refer 3 ) dry by having any naturalventilation or exh.fans ? Ans:No
(6) Any damaged gas line insulation ? Are the drain lines from the units have reqd slope Or any drain line choke up ?Ans : no
Good Answers: 67
08/31/2010 3:19 AM
Is it chilled water? If yes, at what temp.? I think it is not frosting, it may be sweating and condensed water is falling. The solution is to go for insulation of chilled water pipe.
09/10/2010 11:54 AM
hai,
can u please suggest me for the best insulation what should be used ,make ,company ,vendor in hyderabad.
08/31/2010 4:16 AM
I assume from your description that chilled water is taken to the FCU type ( Cassette type mounted above the false ceiling. Following are few causes
Insufficient or damage insulation of Chilled water piping.
Air leakage above the false ceiling
Infiltration of humid air into the A.C area.
09/02/2010 1:06 AM
Check the pipe was Insulated or not, it may be chill water or direct refrigerant system.
Then check for condesate drain line, try to use p trap in drain line
Register to Reply 6 comments
Anonymous Poster (1); chari_eee@yahoo.com (1); maglak (1); manroop (1); mrswamy (1); pritam (1)
