Hello, this is a question for you compressed air gurus out there. We have added to our compressed air circuit a number of 1000 litre air receivers close to high-consumption areas where a pressure drop was being noted. The idea was that the extra air storage in the vessels would reduce the pressure drop, and would enable us to provide compressed air at a slightly lower pressure, thus saving energy to operate the air compressors.
For each vessel, picture a 2" pipe coming off the 4" main pipeline, to which two tees were added, with a valve between them. Each tee was connected to one end of the vessel. All pipes and fittings are 2". Due to the constraints in the area where the vessels could be located, about 6 bends had to be added to each branch leading to the vessels.
My question is this: what is the most energy-saving way of using this system – by having the valve between the tees in a closed position, or in an open position? With the valve closed, the air flow would have to first enter the vessel through one end and issue through the other end to service the operating machinery. With the valve open, part of the air could pass straight to the machinery, and when the system pressure cannot cope with the air demand by the machines, the receiver would deliver additional air to prevent the pressure drop. As soon as the air demand slows down (since the machines' air consumption is always variable) the supply side would replenish the air receiver.
Do you have an opinion on how to best use this system? Thanks for your advice.
