Previous in Forum: 98 Malibu Over-Heating   Next in Forum: Chrysler Crossfire SRT-6 Throttle Response Needs Help
Ultrasonic Diesel Injection Engine
09/03/2010 3:58 AM
Dear all, i have hear about this amazing engine, prototype , have anyone heard before? Your feedback would be valuable , is 30% diesel 70% water mixture.
Good Answers: 48
Re: Ultrasonic Diesel Injection Engine
09/03/2010 4:47 AM
Firstly, I think you have the proportions wrong. 70% fuel and 30% water is more likely.
It has long been known that the injection of water into diesel and petrol engines can aid combustion, improving both power output and fuel economy. I had always assumed that this would be done with a second set of injection equipment for the water. However, I did come across a system that was being developed in Germany about ten years ago for the aftermarket for diesel cars, which did not need an injection system for the water. I assumed at the time that they had found a means, chemically, of emulsifying the fuel and water. I had not come across ultrasonic emulsification. The following is quite interesting, and shows that it is not a new technology: http://www.rexresearch.com/cottell/cottell.htm
I have heard nothing since of the German system, and have seen nothing recently on water injection generally. Where did you hear about this new prototype?
09/03/2010 10:22 AM
The water also helps lower the NOx levels I think, by lowering combustion temperature
Good Answers: 48
09/03/2010 10:47 AM
True
10/19/2010 6:10 AM
That might be the Paul Pantone evap system... use exhast gasses to superheat the intake in a vortex.. basicaly he mantains you can then burn anything including water..
Torque is not cheap
Holzfeller (2); merc600sec (1); norton850 (1)
