Previous in Forum: Duct Design For Vent Stack   Next in Forum: Parylene
8 comments
Location: Thiruvananthapuram, Kerela : Jamshedpur, Jharkhand, INDIA
Injection of Titanium Oxide Powder & High Pressure Water
09/03/2010 9:54 AM
Titanium oxide powder is available in a bin size 100 um.
water under 5 bar is flowing in a pipeline.
We need to mix them so that the mixture can used for the purpose of coating.
Suggest some concepts about about effective mixing.
Uma Shankar Gupta
Good Answers: 16
Re: Injection of Titanium Oxide Powder & High Pressure Water
09/03/2010 11:41 PM
Considering you have not confirmed what percentage of solids or the flow rates there is not much to go by.
However here is one informative place to start:
http://www.vortexventures.com/systems-products/mixing-and-blending/lobestarr-mixing-eductor.html
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
09/04/2010 1:19 AM
ok i will update regarding the flow rate & mixture concentration shortly.
Uma Shankar Gupta
09/04/2010 10:05 AM
The link which you gave was a good one. We got a better visualization of the whole system.
Regarding the problem statement.
We have to inject titanium oxide paste in running water which is flowing at 5 to 10 bar.
Regarding the mixing ratio we have to mix say 6kg of tiatanium oxide in 100 litres of water.
We need to design a feasble mechanical system by which we can feed this paste into flowing water. The injecting or feeding mechanism can be plunger type or any thing.
Kindly suggest some ideas on the this high pressure feeding/Injection system. There can be possible back flow of paste so consider this also so that it doesnot occur.
Uma Shankar Gupta
Good Answers: 16
09/04/2010 10:17 AM
You still have not confirmed the flow rates, however the eductor system shown should be good for your concentration.
Now the challenge is how to reliably get it into the eductor. TiO2 is a very difficult material to hopper and meter. It sticks, packs and dusts everything. Contact the feeder manufacturers below for equipment specified to meter this material:
http://www.powderandbulk.com/conveying/feeders.htm
09/04/2010 10:31 AM
the flow of water is 10LPM.
well we have no idea regarding the metering of titanium paste.
As you said titanium does sticks to the wall so this is also a challenge for us.
Well we donot have any manufactures who will provide us the equipments. We have to develop such equipments. If some similar kind of high pressure injection system exist then kindly tell us about it.
Uma Shankar Gupta
09/04/2010 12:27 PM
Use a ventury suction system and feed in the powder.
You can regulate the amount of powder sucked in using the ventury in parallel (shunt method) and varying the flow through the ventury or ...
Good Answers: 16
09/04/2010 6:00 PM
Where are you located? I can recommend a local manufacturer or representative.
Attempting to re-invent equipment to handle TiO2 will only be an exercise in frustration.
09/05/2010 6:43 AM
we live in jamshedpur(city), Jharkhand(state), in India.
I also feel that re inventing the equipment may frustate us, kindly help us
Uma Shankar Gupta
Register to Reply 8 comments
Delmar (3); LAA_Lucke (1); raviumabrother (4)
