Previous in Forum: Random Vibration Test   Next in Forum: Throughput in Pumping System
First Filling Of Lubricating Oil In Hydroturbine.
09/07/2010 10:43 AM
In hydro turbine ( 60MW ) , ISO VG 46 lubricating oil is generally used in thrust as well as guide bearing. In recent design review meeting of oil purification system (based on centrifuge plus vacuum degassing process),it was suggested that even new oil purchased from reputed oil manufacturer company to be filled in bearing housing after purification only. I am struggling to get convinced with this theory where new oil is also required to be filtered before filling ?
Is there any expert opinion ?
Re: First Filling Of Lubricating Oil In Hydroturbine.
09/07/2010 11:05 AM
the turbine manufacturer for advice. After all, you wouldn't want to risk invalidating any warranty, would you?
The supplier has a reputation to protect. - USE THAT!
09/07/2010 11:47 PM
Proper purification is not bad idea There are many possibilities of lube oil being contaminated during transportation,delivery and storage.No body want to take a blame.
09/07/2010 11:59 PM
I sampled a brand new compressor oil straight from the company's unopend 5 gallon bucket. Sent it in and the sample came back as filthy, in a sense.
Particle Count: 4um-3984...6um-394...10um-31...14um-11.
Not seriously bad but it is a good idea to filter even 'brand' new oil.
I'm campaining for a 3um filtration system. That will give me a more accurate idea of how my comps are really doing.
Good Answers: 58
09/08/2010 6:59 AM
It is very good practice to always top up/fill oil via filters or purifier.
It is very common for oil to be "dirtier" in the as received state than it would be after passing through the machines own filtration system.
09/08/2010 7:08 AM
OK, Agree there is end of improvement in terms of quality.
Just think, when people goes to Automobile shop to change lubricatiing oil, does the mechanic filter Lub. oil or just fill the new oil from container.
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
09/29/2010 12:55 AM
Check out "wefilterit.com". This will clean particles as small as cigarette smoke.......
09/29/2010 2:22 AM
Yeah - and damge the oil due to electrostatic discharge and dieseling. Result - very low particle count and lots of lovely varnish. The first easy to count and prove the second much more damaging and difficult to quantify.
Perfectly good product for automobiles, forget it for machinery where one expects many 10's of thousands of hours from the oil.
Anonymous Poster (4); sblandes2010 (1); The Prof (1); the wrench (1)
