Previous in Forum: Converting a Single Piston Diesel Engine   Next in Forum: Give Me a Name!
13 comments
01 Chevy Cavalier Starting Problems
09/07/2010 9:51 PM
My daughter has a 01 Chevy Cavalier and it will run just fine but on somedays it will take up to twenty to thirty minutes to start. What it does is; she can turn it over and all it does is click, and then nothing. The lights work, the door dings and radio works. It does this for awhile then starts. And no check engine light is on. Sometimes it does this a couple of times of day or it can go for days without doing anything. We have checked the starter and cabels, the alt, the battery, and cleaned the cables,and checked the relays. And all of this is ok. Any suggestions would be greatly appreciated.
Re: 01 Chevy Cavalier Starting Problems
09/07/2010 9:59 PM
First, some terminology.
she can turn it over( what does this mean?) Move the key to the start position? With a reciprocating engine, turn over means that the starter motor is turning the engine "over". So, does the engine turn over for a while and then click when the battery dies?
and all it does is click, and then nothing Or, does it just click? Then suddenly start normally?
Another problem with Chevy Cavalier
09/08/2010 8:51 AM
Certainly has the general symptoms of a starter motor relay going out.
When you say "...checked the relays.", what does that mean? It is very difficult to ascertain the proper function of a starter relay... that is part of the reason they are ten bucks (or so), and fairly easy to change. The car is ten years old... has it (starter relay) been changed ever?
And, as lynlynch says, better definition of terms, please.
Good Answers: 60
09/08/2010 9:03 AM
Alas you have the least reliable car in the world.
try looking at these past questions to see if your question has arisen before.
but i would suspect the crank shaft sensor. or faulty immobiliser
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=cavalier&order=asc
ps next time it wont start arm yourself with some easy start and spray a little into the air intake if it starts the problem is fuel related if it doesnt its electrical
it helps to reduce the possiblities. and report back on your findings,
Good Answers: 60
09/08/2010 9:06 AM
a bit vague.
do you mean it turns over and does not start
or do you mean it just clicks and does not turn over, its important ? thanks
Good Answers: 18
09/09/2010 4:24 AM
If I understand your "terminology", you get a clicking and then no clicking and sometimes instead of clicking the starter motor turn and the engine starts. If i'm right then you have a bad/failing solenoid on the stater motor. Or even worn bushes on the starter motor. I believe what happens is that when the key is turned, the starter is not engaged by the solenoid and all you hear is the click of the solenoid. At other times the starter is in the correct position and the solenoid will engage and no click but a start happens. Have the starter rebuilt and your present problem will go away.
At least the clicking shows thw solenoid still want to work. It is advisable to do both at the same time.
Always learning
Reply Good Answer (Score 4)
09/10/2010 1:38 PM
This is a GA? Give me a break or I should say, give yourself another GA.
Reply Off Topic (Score 8)
09/11/2010 9:05 AM
So I guess that makes five of you now.........I'm watching.........
09/09/2010 10:04 AM
it could be the ignition switch. Try spraying it with a contact cleaner. It could be gummed up inside.
09/09/2010 12:16 PM
The problem is probably a bad starter solenoid. Replace the starter with a high quality rebuilt unit and the starting problem should disappear.
09/09/2010 4:13 PM
Something similar happen to one of my friend, it was related to an anti-thieft system preventing ignition when something wrong is done during the start up routine. It reset itself after about 20 minutes. He just asked the car dealer mechanic to turn it off and it solved the problem.
09/09/2010 4:16 PM
"An anti-thieft system"?
Who in their right mind would steal a Cavalier?
Good Answers: 123
09/09/2010 11:19 PM
Crawl under the lovely car, and attach a jumper wire onto the connection between the starter solenoid and the starter motor power connection itself. bring the other end of that jumper wire to a probe on a test light. the other lead on the test light goes to a known good ground. Position the test light within view of the driver. When the "no start" condition reappears, look at test light. If the light is on, your starter is bad, or you have a bad ground to the starter. If the light is not on, remove the test lead from the starter connection, and re attach it to the small purple wire on the starter solenoid. Again when not starting for her, is the light coming on? if so, solenoid is bad. If not, wiring to the starter solenoid is bad. Continue at the neutral safety switch, or clutch interlock switch. Then the ignition switch. again purple wire is the wire powered when starting. Good Luck.
Bob
09/10/2010 2:00 AM
Try replacing the ignation switch. This might solve the problem
Anonymous Poster (4); bob c (1); DennisWaller (1); Doorman (2); jvrj (1); lyn (1); peterg7lyq (2); Rheolog (1)
