Previous in Forum: Cable Fault Locater   Next in Forum: Alternator Synchronization
Relay Clarification
09/08/2010 3:33 AM
Need some help to confirm if the relay contacts in the link below can handle .5 amp @ 120VAC. The contacts of the relay wire to a Quantum Digital input module. The data sheet shows inductive loads for make and break. I'm using this relay to wire to a digital input module which I believe is a resistive load. I believe this is not an issue just need some confirmation.
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/pp/700-pp020_-en-p.pdf
Re: Relay Clarification
09/08/2010 3:35 AM
Forgot to mention I'll follow up with manufacturer.
Good Answers: 181
09/08/2010 3:57 AM
You'll have no problem with the relay.
Just out of interest what are you using a Quantum PLC or drive.
09/08/2010 4:19 AM
The bit of the datasheet with the table of current-handling is a bit confusing - the "Make/Break" section is refering to DC only.
The important reference is "B300" (you'll find it listed in table 5 on page 1-40 of the Safety Products catalog, which also gives Utilization Category details).
As Tony said, you'll have no problem.
09/08/2010 11:34 AM
YES!
CARPE CRUSTULORUM!
Good Answers: 18
09/09/2010 2:02 AM
You'll have no problem, but make sure the resistance of the relay contacts dont interfere with the required resistance of your load. However the manufacturer is your best bet.
Always learning
JohnDG (1); jvrj (1); not so smart (1); rabat (1); TonyS (1)
