Previous in Forum: Seeking Arc Flash PPE   Next in Forum: DOL Resistance Starting Current
Paper Lead Cable
09/08/2010 4:23 PM
we need to divert a paper lead cable and remake the termination. how do we do this
Re: paper lead cable
09/08/2010 4:28 PM
I assume this is what you are after.
3M PILC Splice supplies?
Re: Paper Lead Cable
09/08/2010 7:26 PM
You will need to locate a cable splicer who is familiar with this type of cable. Very complex work. Years of experience needed.
Good Answers: 181
09/08/2010 11:54 PM
You say you want to remake the cable termination? Do you want to lengthen the cable or shorten it?
What voltage is it?
What size is it?
09/09/2010 1:39 AM
the cable will be shorter. it is for 440V. 185mm aluminium i thin from looking at the termination non of us on site have had any thng to do with paper lead before
Good Answers: 181
09/09/2010 4:47 AM
CMP products do some good cable glands for lead sheath cables complete with heat shrink accessories to seal the cable.
They used to provide an instruction booklet with instructions as to how to strip and prepare the cable.
Good Answers: 131
09/09/2010 11:01 AM
Raychem (Tyco Electronics) also has an excellent line of heat-shrink products for splicing and terminating cable of various constructions, including lead/paper. However, whatever product you choose, you should have a trained, qualified person install the terminations since they are not trivial to install.
Good Answers: 181
09/09/2010 7:14 PM
At up to 660V I'd expect a competent tradesman to follow instructions. I had to! My first project involved 40 paper/lead terminations, all I had to go on was CMP's booklet.
I can now joint up to 33KV
Anonymous Poster (1); Doorman (1); PeterT (1); TonyS (3); wareagle (1)
