Previous in Forum: How Does A Plasma Cutter Really Work   Next in Forum: Synchronizing 2 AC generators
Can I Measure Audio Frequencies with this?
09/09/2010 1:34 AM
This is a HANTEC portable 60MHZ oscilloscope.
Because there are versions of 10, 20 and 40 MHZ, I was wondering if it is also good to measure audio frequencies. I would like to have your opinion about it and if one of you is using it, also your experience with this. Thanks for the help.
Re: Can I measure audio frequencies with this?
09/09/2010 3:18 AM
It's way over-spec'd for audio frequency applications[1] - but it can certainly be used.
[1] May be useful if you're using a switching audio amp (Class D), but even the 10MHz version would probably do for that.
09/09/2010 10:16 AM
Thank you. The reason I opt for this is that by coincidence I can buy this scope for less than $500.00 and the 10 MHZ version for $200.00 more.
Because of the quantities and stock.
I am just all round electronics engaged and thought the 60 MHZ could also serve in TV, transmitters and heterodyne.
Can it also be used for looking at digital pulse trains too?
09/09/2010 10:17 AM
Yes.
