Previous in Forum: Spring Pendulum & Torque   Next in Forum: Minimum Temperature for ASTM A694 and ASTM A860
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Vent Connection in OWS
09/09/2010 5:44 AM
Can anybody let me know why do we need to provide the vent connection (4"-6" vent line left up to safer place at height) in underground oily water service manholes? Do we need to provide in every OWS system?
Atul singla
Pathfinder Tags: vENT CONNECTION IN ows
Good Answers: 49
Re: Vent Connection in OWS
09/09/2010 11:34 AM
Because the oil on top of the water continually vaporizes, and the vents keep the fumes below the flash point concentration.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
09/09/2010 5:34 PM
In the first place,oil should be separated from OWS system before waste water is discharged into the nearest waste water network.Oil separators of different make are available in market. Vent is inevitably required in all OWS system.Vent Pipe size and and the extent of protrusion above grade is a matter of design issue and relevant code should be consulted.
09/10/2010 9:10 AM
Have you ever tried to remove liquid from a tank without a vent..........you may find it rather difficult.
It is also fitted to prevent over-pressurisation.........of the tank when filling it.
That is apart from previous mentioned reasons..........you will generally find that if the tank contains a flammable liquid, even a small amount, if the vent is over a specified diameter it would probably have to be fitted with an anti-flash gauze/device.
Register to Reply 3 comments
abcplmb13feb (1); energygod (1); MOBI (1)
