Previous in Forum: AC to DC adaptors - Regulated vs Unregulated   Next in Forum: Crane Hoist with Ward-Leonard Control
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Base Value of a Substation
09/10/2010 4:47 AM
hello tech
what do you mean by base value of a substation?
Pathfinder Tags: base value
Re: base value
09/10/2010 4:56 AM
I don't know. What do you mean by base value of a substation?
tech
Re: Base Value of a Substation
09/10/2010 12:17 PM
Substation base rating is the rating usually at 55C without any cooling equipment installed. Some subs may have a 65C rating.
Good Answers: 170
09/11/2010 2:42 AM
I assume that you are referring to the fault current calculations in a substation. If so, in a substation where there are many voltages involved and you need to calculate the fault level at many locations in the network, it is advisbale to convert the various impedances of the network referred to a common base. And, this is called the base value. It can be Base Voltage, Base MVA & base Impedance.
09/11/2010 5:17 AM
Thanks buddy
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
09/12/2010 1:41 AM
Refer power system analysis.
If you can't find a way, make one........
Anonymous Poster (1); electricalexpert65 (1); hithuanand (1); justinanto1987 (1); wareagle (1)
