Previous in Forum: Teflon/P.T.F.E. Coating   Next in Forum: Requirement of Hydraulic valve
Turbine Differential Expansion
09/10/2010 4:31 PM
What will the emergency operation be if the D.E. increases while tripping the turbine while on turning gear?
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: TURBINE DIFFERENTIAL EXPANSION
09/10/2010 5:16 PM
I'm sure I'm not the only one who read this and became thoroughly confused.
Please rephrase the question...
Sometimes my thoughts are in a degree of order so high even I don't get it...
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Turbine Differential Expansion
09/11/2010 1:30 AM
Let's see...how about, "run like ^$@&"?
Seriously, please elaborate. Your query is not clear.
Speak softly and carry a big stick.
09/11/2010 8:30 AM
You mean: a Steam turbine is being rotated by auxiliary motor when not in operation (No steam running) to keep it balanced.
This operation (if that is your meaning) is not primarily because of differential expansion requirement, but to help keep the Turbine shaft straight and prevent it from bending during stoppage while there is still heat within the turbine and within the shaft etc.
IF THE MOTOR TRIPS, there should be some emergency means of rotating (at very low speed I presume !) the shaft manually or else until safe to leave it. Otherwise, something is missing in your installation or read some more accompanying instructions for this purpose.
09/11/2010 9:59 AM
To expand a bit on what LAA just said, the turning, or jacking, gear is engaged after shutdown (tripping) to allow the rotor to cool down and maintain it's axial straightness by slowly rotating it; i.e., the shaft will 'sag' and be not be true if allowed to cool down in a static state.
This has nothing to do with differential expansion which is the change in axial length of the rotor due to change in temperature of the rotor.
The turbine cannot be tripped while the turning gear is engaged because the turning gear & motor would have long ago left its place of installment (quite violently) had you put steam to the unit with it engaged. That would have caused an emergency situation!
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
Register to Reply 4 comments
ChaoticIntellect (1); LAA_Lucke (1); mareng (1); standarded (1)
