Previous in Forum: Line Sizing   Next in Forum: Ash from Banana Peeling
Fluid Consumption
09/11/2010 8:10 AM
How to size fluid inlet flow to a pan containing emulsion with a roller supplying fluid to yarn . The roller is dipped in pan and the fluid is suplied to pan to maintain its level. We know fluid consumption on yarn as 0.5 kg/hr. And emulsion roller dia and length is 0.5*0.5 ft with rpm as 10.
Be not afraid of growing slowly, Be afraid only of standing still.
Good Answers: 97
Re: Fluid Consumption
09/11/2010 9:39 AM
With the fluid level in the pan as your reference, this level can be used as a set point for control of inlet flow. you will need to determine what type of level sensor is compatible with you emulsion. These level sensors can be as simple as a mechanical float valve or as complex as capacitance,radar,ultrasonic etc.
CRTL-Z
09/11/2010 1:40 PM
It should be sized to provide 0.5 kg/h. Is this homework?
Register to Reply 2 comments
