Previous in Forum: Heat Exchanger Capacity   Next in Forum: Party Wall Responsibiliy
8 comments
Velocity of Air in Wessel.
09/14/2010 3:39 AM
i want to calculate air velocity inside the vessel in a meter per second (the air enters from the bottom & passed through top end , wessel is cylinder shaped) , so how can i calculate the perfect velocity ?
Re: velocity of air in wessel.
09/14/2010 3:45 AM
Velocity = volumetric flowrate / cross-sectional area.
What does "perfect" mean?
09/14/2010 7:26 AM
This last batch of questions looks like homework to me.
Re: Velocity of Air in Wessel.
09/14/2010 5:27 PM
hi dear ,
calculate the volume of vessel v=2πRL
be sure perfect
L =the length of vessel
π =3.14 R=internal raduis
calculate the time by stop watch
Q = Volume \ Time
velocity = Q \ cross section area
choose your unite in calculation per meter
to have velocity m\s
smile engineer : B.R.abo Ismail
" nothing is impoosible with hard work " smile engineer : abo Ismail
Good Answers: 183
09/15/2010 7:54 AM
What you compute is NOT the vessel volume but ONLY the mantel area!
The cross area is A= π*R^2 and *L = V
Are sure about the right use of the word "perfect"?
09/15/2010 6:39 PM
ooooo dear
i am very sorry , i was very tired .
you are alright
perfect = there is no loss due to collision between vessel and fluid
that i understand .
Good Answers: 183
09/16/2010 3:33 AM
In fact your answer is not totally correct since the velocity is NOT same across the whole section. The distribution depends on:
- ratio between entry area and cross section
- ration between length and diameter (if cylinder)
- ratio between out let and cross area.
- inlet air velocity
And the answer cannot be done before the OP explains what is the meaning of "perfect" in his question.
09/21/2010 11:22 AM
hi , iam very sorry for any mistake ,error .
please give us the correct answer .
i wiat your answer .
Good Answers: 183
09/22/2010 4:10 AM
You did not answer the question about "perfect".
Register to Reply 8 comments
Anonymous Poster (1); lyn (1); nick name (3); smile engineer (3)
