Previous in Forum: Grounding of Generators   Next in Forum: Choose MCCB Sizing and Calculation
Hydrogenerator Line Charging /Condensing Ability:
09/14/2010 7:08 AM
Could somebody justify the following statements in a manual:
If the generator will be required to energize relatively long EHV transmission lines, the line-charging requirements should be calculated and a generator with the proper characteristics specified. The line-charging capacity of a generator having normal characteristics can be assumed to equal 0.8 of its normal rating multiplied by its short-circuit ratio, but cannot be assumed to exceed its maximum rating for 70 °C temperature rise. Often it will be desirable to operate generators as synchronous condensers. The capacity for which they are designed when operating over-excited as condensers is as follows, unless different values are specified:
Power Factor / Condenser Capacity
0.80 / 65 percent
0.90 / 55 percent
0.95 / 45 percent
1.00 / 35 percent
Re: Hydrogenerator Line Charging /Condensing Ability:
09/14/2010 3:31 PM
A transmission line with no-load is capacitive in nature, it is synonimous to connecting a generator to a capacitor bank, more appropritely you need to calculate the capacitance of the long transmission line under consideration for a satisfactory conclusion.
In case you need to regulate the voltage drop at the far end of the transmission line, given pf / cc chart has to be referred to.
Knowledge sharing is a WIN-WIN situation
09/15/2010 7:04 AM
Friend, I think for a short HV transmission line, the generator should run at lagging power factor and over-excited, and I am interested in the calculation of condensing capacity of hydrogenerators at various lagging power factors.
Regards,
Register to Reply 2 comments
