I forgot my password.
Don't have an account?
a pump and turbine whose functions are to send oil to a cenrifugal compressor to seal up hydrogen gas from going to the wong place, usually have a problem of gradual drop in discharge pressure, even after repairs. what can be responsible
If you have been using the recommended material and following the procedures the only thing left is to check shaft and bearing alignments.
Is the oil foaming, pressure gauge air bound? relief valve passing, oil temperature increasing?
