Can anyone elaborate the term "K-factor" of valve.? Referring valve specification data sheet of AFT-Fatham, it gives different K-factor for 10% open to 100% port globe valve and tabulated below :
| Globe valve, standard |
| % Open port | K-Factor |
| 10 % | 100 |
| 20% | 25 |
| 30 % | 11 |
| 40 % | 7.5 |
| 50 % | 5.5 |
| 60 % | 4.5 |
| 70 % | 4.0 |
| 80 % | 4.0 |
| 90 % | 4.0 |
| 100 % | 4.0 |
How to understand this K-factor ? I do understand Cv or Kv fairly but this K-factor seems to be something different ? A very wild guessing may be head loss in meter but this is also not logical because pressure drop across 10% open standard ball valve can not be 100 mWC ? If it is a constant of Kv2/2g formula to calculate head loss, then again what are the criteria that influence this k-factor ? A lot of things like coefficient C of NFPA-14 or k-factor of fittings of Perry hand book etc. complicating it further.
