Previous in Forum: RCD for Heat Trace   Next in Forum: LT & MV Cable
8 comments
Copper Bus Bar
09/18/2010 3:40 AM
Copper bus bar Size is 25mmX03mm & its length is 20 mtr.
so i want to know total weight in kg.of 20 mtr. bus bar
Re: Copper bus bar
09/18/2010 3:50 AM
Your teacher is trying to teach you about density, you may want to look it up.
Charlie don't surf.
Good Answers: 181
Re: Copper bus bar
09/18/2010 5:14 AM
Weigh it on scales.
Or work from 8.96gm-cm3
Re: Copper bus bar
09/18/2010 7:59 AM
The answer is 42. I'll leave it to the student to find the reason.
Good Answers: 181
Re: Copper bus bar
09/18/2010 3:28 PM
For that he'd need Deep Thought
Re: Copper bus bar
09/19/2010 10:53 AM
Well done redfred!
Good Answers: 11
Re: Copper Bus Bar
09/20/2010 7:35 AM
Apart from the jokes above (which I like), the easiest way for a simple approximate check is as follows :-
width * height * 8.9 / 1000 = weight in kg per metre length
so for your example 25 x 3 = 75, x 8.9/1000 = 0.6675 x 20 = 13.35kg
Hope this helps you and others.
rogerggbr
Good Answers: 181
Re: Copper Bus Bar
09/20/2010 3:54 PM
2 days to get his homework done for him.
Could do better.
What's the point in a school or collage setting homework if we do it for them!
Re: Copper Bus Bar
09/20/2010 4:04 PM
Maybe the point is that if we keep doing his work then our jobs will be secure. Obviously by not doing this simple work he will never be able to do the real work.
Doorman (1); redfred (2); rogerggbr (1); stevem (1); TonyS (3)
