Previous in Forum: LT & MV Cable   Next in Forum: 3-Phase Ind. Motor Protection, Circuit Breakers
Hello Dear, I Want Understand Transformer Tan Delta Test
09/18/2010 5:26 AM
knowing how test work
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
Re: hello dear,i want understand transformer tan delta test
09/18/2010 5:46 AM
In a pure capacitor current leads the voltage by 90 degrees. when a resistor is introduced in between the current leads an angle less than 90 degrees. Similarly in a Dielectric material when a cavity or deterioration starts , the life of the material starts deteriorating , as there is a resistance getting added and hence leakage current increases In tan Delta we find the difference in the angle and periodically note down the pace at which deterioration takes place search earlier threads.
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Re: very thanks
09/23/2010 8:32 AM
very thanks sms149,realy thanks
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Re: Hello Dear, I Want Understand Transformer Tan Delta Test
09/19/2010 9:16 AM
Can be found out by dividing leakage current by capacitive current.
Actually it determines how much % leakage current flows of capacitive current.
Device which shows less value will have better insulation.
If you can't find a way, make one........
Re: very thanks
09/23/2010 8:33 AM
very thanks justinanto1987,realy thanks
Register to Reply 4 comments
Anonymous Poster (2); justinanto1987 (1); sms149 (1)
