Previous in Forum: 3-Phase Ind. Motor Protection, Circuit Breakers   Next in Forum: Next Generation Ceiling Fan Motors
How Many mmsq Aluminium 4 Core for 60 KVA 3phase 400V 50 Hz
09/18/2010 9:50 AM
I need to connect a 60 KVA load to source of 400V 3phase about 20 mts away by a four core aluminium unarmoured cable open to air. Ambient temp. reaches to a max. of 50 degree celcius. How many sqmm cable should be used?
Pathfinder Tags: aluminium cable
Good Answers: 181
Re: How Many mmsq Aluminium 4 Core for 60 KVA 3phase 400V 50 Hz
09/18/2010 2:16 PM
Have you looked in the ratings table? The answers in them!
09/21/2010 2:12 AM
Minimum 95 mm2, if derating factor on proximity with other cables is considered. If it is to be laid alone with no possibility of other cables being laid with it in future, then you may go for 70 mm2. Check the cable catalogue also.
BB Raina
09/21/2010 5:01 AM
Thanks.
Register to Reply 3 comments
BB Raina (1); schandra (1); TonyS (1)
You might be interested in: KVA Meters, Core Shafts and Mandrels, Core Modules
