Previous in Forum: Aluminum Casting   Next in Forum: PE Powder Going Out to ATM Through Equalizing Line
Line Pipes 3 1/2" Grade L80 API-5CT PSL2
09/21/2010 7:10 AM
Dear all,
i'm searching for 3 1/2" carbon steel line pipes according to API-5CT PSL2, the grade has to be L80.
Please give me a feedback.
Re: Line Pipes 3 1/2" Grade L80 API-5CT PSL2
09/21/2010 11:31 AM
No, you're not. You're inviting others in the engineering community to do your Google search for you, otherwise you'd have done it by now.
Good Answers: 61
09/21/2010 2:51 PM
Try here:
http://www.bikudo.com/product_search/details/32937/seamless_line_pipe_api_5l_psl1_and_psl2.html
I found this:
Product Description
Specification: API SPEC 5L PSL1 PSL2
Grade: B, X42, X46, X52, X53, X60, X65, X70
Size: From 1/4" to 28", OD from 13. 7 mm to 711. 2 mm
Schedule: SCH20, SCH30, SCH40, STD, SCH80, XS, SCH60, SCH80, SCH120, SCH140, SCH160, XXS
Length: 5. 8 meters for 20' container, 6 meters to 12 meters for 40' container
Packing: In bundles, Varnish coating, Ends can be beveled or square cut, End capped.
The pipes can be 3PE coated.
In case you have any other questions, please email me to linepipechina at gmail dot com, I will be very glad to reply you as soon as possible
Do it once and do it right
09/22/2010 9:59 AM
Hello,
thank you very much for your help.
Anonymous Poster (1); PennPiper (1); romanpehl (1)
You might be interested in: Heat Pipes, Line-shaft Spools
