Previous in Forum: Boiler Efficiency-Loss Method   Next in Forum: Vibration Probes
Keyphasor and Eccentricity Probe
09/22/2010 10:55 AM
What is the difference between keyphasor and eccentricity probe?
Life is for one generation, a good name is forever.
Pathfinder Tags: keyphasor
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: Keyphasor and Eccentricity Probe
09/22/2010 1:37 PM
The timing mark on a machine shaft or wheel is sometimes called a keyphasor. An eccentricity probe can measure the orbital energy, angular momentum, or other dynamic measurements that are eccentric from the normal specs…this isn't homework is it?
Go green, use a solar powered light saber...
09/23/2010 10:11 AM
If u r interested pls. explain some what briefly about key phasor, iam not getting your point regarding key phasor, because basically iam a electrical engineer.
Good Answers: 19
09/23/2010 1:11 PM
When I worked with turbine engines in 1985-1991, we were building a number of experimental shaft-driven turbines. We would have the machinests engrave a mark on the shaft (a keyphasor), much like the timing mark on some older vehicle engines. It is a physical mark to be used as in indicator, along with all the other sensors.
Good Answers: 19
09/23/2010 1:54 PM
Also see my answer to your concurrent "Vibration Probe" post...
Register to Reply 4 comments
