Previous in Forum: C2 File Example   Next in Forum: Pneumatic Piping
Mill Operating Window
09/24/2010 3:21 AM
Hello, I want to know about '"Mill Operating Window" regarding coal mill operation in Power Plant in some details. Please come into a discussion. We are now facing problem in mill operation causing excessive retaintion, flame instability, even we have experienced mill inside fire. We are very keen to solve the problem and need help.
Thanks.
Suranjan Chattopadhyay
Re: Mill Operating Window
09/24/2010 9:02 AM
Hello friend,
I am also working in Pulverised Coal boiler of 200TPH, 68kg/cm2 capacity, using a ball mill of steins 3448 make. After seeing your question, I checked in google for "mill operating window" and found a number of sites for it. Yo can check that way. Here is one of them :-- http://teide.cps.unizar.es:8080/pub/publicir.nsf/codigos/0122/$FILE/cp0122.pdf
By simple logic, In Ball mills, Excessive coal retention may be due to grinding media qauntity not proper [ Milll current low] , Grinding media sizes and ratio low [ If mill current is OK] , worn out mill liners , Heavy chokage in Mill classifier,leading to more coarser particle generation and its recycling in the mill.
Please give some more details like ATM Flow, Bypass air flow, Coal O/L temp, whether it is happening during rainy season? , whether mill fire happened in single side of ball mill working?whether it was mill fire or duct fire and ? whether mill is frequently getting choked?
09/24/2010 2:07 PM
The OP is with E Mill not BBD.
Normally vertical Mills will have mill fire problem in case of
a) Over fine-ness
b) Excessive %volatile
c) Coal accumulation (especially powder)
d) Excessive PA Temperature
and a few other parameters (in fact excessive pyrites, coal quality etc also some times may result in it)
Register to Reply 2 comments
