Previous in Forum: Identification of rust in alloy steel   Next in Forum: RGD Formulation
Engineering Fields - Chemical Engineering - New Member
Formaldehyde-Water Equilibrium Curve
09/24/2010 1:51 PM
Our project is about manufacturing formalin & Distillation column is there to design. We have methanol (un-reacted); formaldehyde (via reactor) & water as input species to distillation column. Thus, we have to design multicomponent distillation column such that our product contain 0% methanol or methanol is 100% recovered. I thus need VLE diagram of formaldehyde & methanol; the latter can be acquired via Perry but I have no luck with the former. plz do help
Chemical Engineers are like high Temperatures & high Pressures
Location: Guatemala, The Netherlands and any were in the world
Re: Formaldehyde-Water Equilibrium Curve
09/25/2010 6:28 AM
Well first making Formaldehyde with 0 % methanol is not possible because of the stability.
So You will not find this
Also Formaldehyde is a gas that you have to disolve in water
Amount of methanol when you are very well running (do not know because not enough statics given from your distillation colom) But with a very normal disign you can get to 1,0 to 5.0 % without any problem.
Hope this will help you
For an answer to any problem in Chemistry
09/25/2010 7:17 PM
^^Thnx I know we can't get 100% methanol free formalin; but we have assumed nearly pure products. Sir what I really am asking is a equilibrium curve of formaldehyde-water system; just like ammonia-water system which too is a gas. Do provide me some resources where I can get this
Also if you may do provide me a general algorithm for designing multicomponent distillation column
10/05/2010 6:22 AM
Hi,
I designed an absorption column using AspenPlus simulations as an undergraduate project.
We had difficulty designing the column since we realised that formaldehyde is poorly soluble in water. However the formalydehyde does reacts with the water to form low moleculare weight polymer chains which readily disolve in water making the computation of the seperation processes very complex.
Fortunitally there are many authors whom have developed models to predict this behaviour and simplyify the calculations.
Unfortunitally I do not have any of the references on hand but a quick search in google scholar should help - try searching for: water - formaldehyde models.
Stephen
10/05/2010 12:22 PM
see this http://www.scribd.com/doc/38763854/Formal-In Formaldehyde is readily soluble in water but without VLE data how can I know the no. of stages if I am using plate type absorption column
Register to Reply 4 comments
Anonymous Poster (2); Chemist59 (1); nightcrawler (1)
