Previous in Forum: For Admission in B.Tech in Mech. From Distance   Next in Forum: Advantages of installing Economizer in Boilers
Engineering Fields - Piping Design Engineering - New Member
Hydrogen Peroxide Material
09/25/2010 1:00 AM
I have seen SS316 being used for Hydrogen Peroxide service and that too preferable SS316 L. My doubt is why we cant use Alloy 20 or Hastealloy material for this hydrogen peroxide service? Could have raised this issue in Chemical Section also but looking for a mechanical reply.
annu
Good Answers: 137
Re: Hydrogen Peroxide Material
09/25/2010 12:50 PM
You probably could, I would check with supplier of H2O2 e.g. Interox. But likely to be more expensive than SS316L.
Cheers.......Codey
09/26/2010 12:47 AM
The Material Selected
Hastelloy-Cr
Interacting with the Chemical
Hydrogen Peroxide 100%
Has a Compatibility Level of
A-Excellent
source: http://www.coleparmer.com/techinfo/chemcompresults.asp
Explanation of Footnotes
1. Satisfactory to 72°F (22° C)
2. Satisfactory to 120°F (48° C)
Ratings -- Chemical Effect
A = Excellent.
B = Good -- Minor Effect, slight corrosion
or discoloration.
C = Fair -- Moderate Effect, not recommended
for continuous use. Softening, loss of strength,
swelling may occur.
D = Severe Effect, not recommended for ANY use.
N/A = Information Not Available.
09/26/2010 1:51 AM
Check for decomposition in presence of trace metals before changing the containers etc.
H2O2 can violently decompose in presence of trace metals such as transition metals, Manganese etc.
Good Answers: 137
09/26/2010 9:06 AM
I worked on a water treatment job some years ago and if I remember right the spec said SS tanks had to be polished internally.
Also if ball valves are used they must have a hole drilled through the ball so there is no trapped volume of liquid. Otherwise this could decompose and liberate oxygen, causing high pressure.
Cheers.......Codey
09/27/2010 3:24 AM
You can use Alloy 20 but the corrosion rate depends on the H2O2 conc and operating temperature, i've found data on Alloy 20 and at 100% conc the max corrosion rate is < 20 mpy. (NACE CORSUR)
here you have some good info on materials compatibility with H2O2:
http://www.outokumpu.com/applications/corrosion/view_details.asp?name=HY18
Materials of Construction for the Storage of Hydrogen Peroxide
http://books.google.it/books?id=KXwgAZJBWb0C&amp;pg=RA1-PT421&lpg=RA1-PT421&dq=alloy+20+hydrogen+peroxide+corrosion&source=bl&ots=ReNWAuzuXg&sig=I4hLzXdmY-jJRPnZixwptRVoEbM&hl=it&ei=t0OgTOK4ApCMswadja3mDg&sa=X&oi=book_result&ct=result&resnum=2&ved=0CCMQ6AEwAQ#v=onepage&q=alloy%2020%20hydrogen%20peroxide%20corrosion&f=false
S
corrosion & rust prevention
Anonymous Poster (1); awelch (1); Codemaster (2); strider6 (1)
