Previous in Forum: What Minimum Size Cable Required   Next in Forum: Total Weight of Transmission Tower of 66kv
How Much Current Can Supply a Battery
09/28/2010 2:08 AM
A battery say 12V 45AH means it can supply 45A in one hour, 22.5A in 2 hours.......... Can it supply more than 45A (say 90Amp in 0.5hours)?
Re: How much current can supply a battery
09/28/2010 2:26 AM
May be but not necessary.
There is a parameter called "maximum discharge current" of the battery which is independent of its stored energy (AH)
This may be quite high (about 9A for AA cells) but not necessarily one that meets your requirement.
The internal resistance of the cell usually takes care of it - the terminal voltage drops and thereby limiting the current. However it is not safe to depend on it, since if it does not properly regulate, the cell will be destroyed.
India - Member - New Member
09/28/2010 3:39 AM
View product profile on web site hbl.in
Download one of product catalog and understand battery discharge capabilities. Details are available.
When was last time you did something for first time.
09/28/2010 6:49 AM
You need more understanding in the subject and in mathematics.
Reply Score 2 for Off Topic
Good Answers: 140
09/28/2010 8:34 AM
Ahhh... ya think that is maybe the reason he is here asking questions? Why dont you offer some of the things you say the OP is lacking?
09/28/2010 6:55 PM
The battery manufacturer usually determines the maximum discharge current for you Pilgrim.
Re: How Much Current Can Supply a Battery
09/29/2010 12:31 AM
Generally the AH rating mentioned in any battery is 10 hour rating. For example, the 45AH battery is designed to deliver 4.5 A continuously for 10 hours.It is the continuous rating./ However in substation, where the battery is used for protection purpose, simaltaneous tripping of number of feeders,It can supply even 45A for a short duration , and successfully trip all feeders,provided the voltage dip is within the allowable limit./ Instead If you are using Battery source for for MOD (Motor Operated Devices) switches, you have to size the battery only based on the 10 hour AH rating.
There is nothing either good or bad, only thinking make it so -
Anonymous Poster (3); Happy singh (1); North of 60 (1); Panneer Selvam (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
