Re: Design of automatic peak detector and hold circuit
09/29/2010 7:05 AM
How fast to you want it to operate (maximum dV/dt of input)? What is the maximum permissible droop rate? What is the maximum repeat rate/minimum reset period? How are you going to reset it? What is the range of input voltages? What accuracy do you need?
Have you thought this through?
09/29/2010 7:55 AM
Yeah but what is 'it'?
You need to give full information if you want helpful answers.
You have answered about 20% of John's questions.
If 'it' is from a source with a reasonable output impedance then an R and a C will do the job with maybe a transistor to dicharge the C, and a sprinkle of diodes...(cats like diodes).
