Hi,
I am planning to install an immersion heater in the oil sump of our GE Gemini FS-704 reciprocating compressor.
Oil: Shell corona P-150
Capacity: 170 Liters.
Operating temperature during operation of the compressor is 60-65 deg C
The purpose of this heater would be to keep the oil warm when the compressor is standby. The heater will maintain a temperature of around 50 deg C.
Our Problem: It was observed that during the winter season,
when the compressor was in standby condition, the lubrication oil temperatures
dropped to a certain level around 34o C. As the oil viscosity was
low, this resulted in the tripping of the compressor on low lube oil pressure
during startup.
This heater will have a built in thermostat and will only run when our auxiliary lube oil pump is running.
What I need is heater that will suit my situation. I have a 1" NPT plug hole available at the sump bottom of the crankcase.
