Stone crusher machine is a general-purpose machinery and equipment in industrial production and is mainly used to make sands and gravels. According to the final size of stone, we use different stone crusher to work together. Stone crusher machine can be divided into many types, according to working principle, such as jaw crusher, impact crusher, cone crusher etc. Our stone crusher machine contains jaw crusher, impact crusher, cone crusher, VSI crusher, mobile crusher, hammer crusher etc. According to customer's request, we can configure different sand making production line and stone production line. Our stone crusher machine has become the best choice for customers.
Working principle of stone crusher machine:
This impact crusher machine crushes materials with impact force. When the materials enter the blow bar area, they are crushed due to the high-speed impact of the blow bar and are thrown to the impact plates on the rotor for secondary crush. Then the materials will be shot back to the blow bar again for the third crush. This process repeats until the materials are crushed to the required size and discharged from the lower part of the machine. The size and shape of the finished powder can be changed by adjusting the gap between the impact rack and rotor support. The machine employs self-weigh security device in its back frame. When other objects enter the impact cavity, they will be forced out of the machine by the impact rack in the front and back of the crusher machine.
Impact Crusher machine Working Principle
Impact Crusher machine is mainly used in secondary crushing; it can crush material whose crushing compression strength is not more than 320mp. It is suitable to produce high rank highway hydroelectric and building material.
When the materials enter the field of the hammer, it is impacted by the hammers, thrown onto the impact plate, and crushed. The stuff springs from the impact plate, is impacted by the hammers again, and thrown onto impact plate. This process will last until the stuff meets the requirement and falls from the machine. Adjusting the distance between impact frame and rotor frame can change the shape and size of the output.
Shanghai Shenbang series of impact crusher is widely applied in mining, transportation, energy, construction and chemical industry. They are ideal choice for crushing and screening. This machine features reasonable structure, high productivity, easy operation and maintenance and safe performance. The most outstanding advantage of impact crusher is that its finished powder is in good, cubic shape and without tensility and cranny.
Crusher machine Features and Benefits:
1. High reduction ratio and crushing efficiency.
2. No-board connection. The blow bar with high chrome (high chromed blow bar).
3. Impact plate with a special shape.
4. Crushed product with cubical shape.
5. Easy maintenance and reliable operation.
