Previous in Forum: Is There Such a Formula?   Next in Forum: Air Condition
Boiler Feed Water Heater
10/05/2010 12:17 PM
Sir,
If in deaerator itself sufficient temperature available then why Boiler Feed Heater is needed in Combined Power Plant as same steam it is taking from boiler only & how it is affecting boiler efficiency.
Thank u
Pathfinder Tags: boiler feed water heater heater
Good Answers: 29
Re: Boiler Feed Water Heater
10/05/2010 1:02 PM
The boiler will obviously be more efficient the closer the feed water temperature is to the process target temperature.
10/06/2010 7:13 AM
This is correct..since we are pre heating the water amount of fuel required will be reduced...But the amount of steam needed to heat is taken from the same boiler...So in this case how is it possible..
With Regards
Register to Reply 2 comments
