Previous in Forum: CAT Generator Engine Model 3406, Oil Pressure Switch   Next in Forum: What Are the Articles to Update in Automobile
Pipe Flow
10/12/2010 3:50 AM
air flows through a pipe of internal dia D1 at pressure P1, flow Q1.
the diameter of pipe uniformly increases to D2, what is the effect on pressure and flow. how can P2 and Q2 be determined ?
Good Answers: 67
Re: pipe flow
10/12/2010 4:18 AM
I suggest you to go through your text books or apply simple CS for such questions. Howevere I reply as follows:
1. Q1 = Q2, as same quantity of air per unit time passes through both the points.
2. P1 > P2, as downstream pressure will always be lower than upstream in pipe flow.
If Q = 0, then P1 = P2
Good Answers: 183
Re: pipe flow
10/12/2010 4:58 AM
I suggest to have a look at what Bernoulli wrote, with other words the sum of energies (potential + kinetic) is a constant if losses are neglected and fluid incompressible.
Good Answers: 67
Re: pipe flow
10/14/2010 7:20 AM
Here Bernoulli's law will not be applicable, because air is compressible.
Re: Pipe Flow
10/13/2010 9:04 AM
HOMEWORK PROBLEM...! ! !
Anonymous Poster (1); nick name (1); pritam (2)
