Previous in Forum: How to Measure Resistivity of Liquid Solutions   Next in Forum: How we Can Increase the Strength of Material
Compatibility Problem
10/12/2010 9:45 AM
I'm a Polymer engineering student. I wan't to have some info about adhesion of Carbon fiber with polyester and epoxy resins in composite. which of the both has greater affinity with CF? I'm working on efficiency of composites with different reinforcement methods so choosing one resin that works the best will allow me to proceed forward and obtaining reliable data.
Re: Compatibility Problem
10/13/2010 8:19 AM
Hello Abdul,
Carbon fibers are usually treated with "Sizing Agents" by most manufacturers for adhesion. This sizing agents may be based on "Silane coupling agents". This surface treatment is extremely important not only for adhersion between epoxy/polyesters and carbon fibers but also load transfer between epoxy to carbon fibers. So if you have fractures at resin (Polyesters, epoxies, phenolic, and cyanate esters) and fiber interface then your load carrying capability of your composite laminate will be affected. Also please pay attention to the type of carbon fiber selection (modulus, strain, and tow sizes). I would recommend epoxies based on my personal experience.
If you are looking for load carrying capability, then select fibers like T-650, IM7, or T1000 carbon fibers(with 3k tow is ideal but 6k might be cheaper). Select an epoxy that is 350 F cure system for high temperature capability
Materials and Process Engineering Guy
10/22/2010 1:50 AM
thanks, that helped a lot. you sound like a real pro at composites!
Register to Reply 2 comments
