Previous in Forum: Tension and Draw Control on Paper Machine   Next in Forum: Auto-Transformer Starters
Double Earthing
10/13/2010 7:57 AM
what happend if we earthed ct secondary in two point in diff protection
Good Answers: 170
Re: Double Earthing
10/13/2010 9:26 AM
Can you ask with a drawing showing the different earthing points?
Re: Double Earthing
10/14/2010 7:28 AM
I mean by two point that the secondary of LV or HV CT is earthed for examble in the marshalling box and in the protectinon pannel .
Good Answers: 131
Re: Double Earthing
10/13/2010 2:06 PM
Depending on where the ground points are and how long the CT circuit wires are, you may change the amount of current the relay will see in its operating or restraint coils. Consider for example the impact of the grounds as shown in the following illustration (taken from GE's "The Art & Science of Protective Relaying," with my additions of the grounds):
Look to your differential relay's instructions for the manufacturer's recommendations on grounding of the CT circuit.
Register to Reply 3 comments
electricalexpert65 (1); hishamageed (1); PeterT (1)
