Previous in Forum: SS330 Materials for Pipes   Next in Forum: Retained Austenite for Quenched Tool Steels
Recrystallization in Metals
03/14/2007 10:01 AM
how much work is necessary for recrystallization to occur.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Recrystallization in Metals
03/14/2007 11:18 AM
Which metals? Which grades? What's your application?
03/14/2007 4:24 PM
The classical definition of work in engineering is the amount of energy transferred to a system in determined conditions. Example, a force aplied to a body x the body travel in the direction of the force.
Recrystallization is a phenomen that occurs in metals under determined conditions that alter its microstructure and alloy elements distribution. It depends on the part geometry, thickness, time, temperature, etc.
Please be more specific in your question.
Humm... suspicious you are...
Good Answers: 243
03/15/2007 7:24 PM
The amount of STRAIN needed for recrystallization depends on the metal and obviously the percentage of cold work applied. The CRITICAL STRAIN ((the amount of strain just needed to initiate recrystalization)) can be anywhere from 0- to 5% elongation in pure tension but is also influenced by annealing temperature . Figures given are for pure Aluminum or Iron (RWK Honeycombe Plastic deformation of metals, ASM, 1984.)
If you draw a very tall sigmoid curve, Temp on y axis, time on x axis, the bottom of tha S is the relaxation area; the next segment denotes recrystallization, and after that grain growth is represented.
This is all specific by metal and obviously your ability to uniformly create strain throughout the section.
Milo
Register to Reply 3 comments
bhrescobar (1); Milo (1); Steve Melito (1)
