Previous in Forum: Current Density Value Suitable for Different 3 Phase Transformers   Next in Forum: Earthing System
Signal Booster - Analog
10/15/2010 7:50 AM
Hello everybody. I have a problem. I want to boost up the analog signal.
Lets see i have an analog signal of 1-10 Volt. lets the signal is 4 volt or 5 volt or what ever let suppose 6volt. i want to make an arrangement that whenever i press a push button signal will rise up and when i release the push button it will go down on its previous stage.
suppose signal is 7volt on VFD. i want to speed up my motor for just few seconds just for 2 seconds or one second. now i want a arrangement that when i push a button signal will start rising from 7 volt to towards 10 volt.and whenever i release the push signal become again on 7 volt.
how can i implement this.
Re: Signal Booster - Analog
10/15/2010 8:20 AM
If you have a 10v supply a resistor or two, a capacitor and a push button will do it, maybe add a diode for good luck?
10/15/2010 3:45 PM
That diode is for more than just luck
Charlie don't surf.
Canada - Member - New Member
10/15/2010 12:22 PM
Why not simply use a potentiometer? You can turn it up or down at will.
Knowledge makes what was impossible, seem easy.
10/16/2010 11:50 AM
Use an amplifier and a switch. Pushing the button switches the amp IN, releasing it switches it OUT.
Register to Reply 4 comments
Elroy (1); stevem (1); user-deleted-1105 (1); WoodwardDL (1)
You might be interested in: Signal Conditioner Chips
