I am interested in finding a source of plastic, polymer, (?) hoops with the following characteristics;
- 30" OD w/ .25 +/- tolerance
- thickness of material comprising hoop to be .38" to .50" dia.
- hoop to be rigid enough to withstand 50 lbs. of compression without compressing more than 10% of its 30" OD *
- HDPE or some material that has a spec. gravity of .94 -.98
- UV tolerant or simply has carbon balck additive
- smoothness or semi-rough not an issue
*ideally, i am looking to replace a .25" dia. Galv. steel (spring steel) hoop of 30" dia. with a non rusting, lighter hoop.
Any suggestions, ideas, go to places?
