Previous in Forum: International Economic and Trade   Next in Forum: Pipeline Inspection
Replacement of Hydrazin Material
10/17/2010 1:12 PM
hello
i am an engineer chemical i woud to ask a question about the replacement of hydrazin material helamin used to treatment water in the steam boilers used in power plants to produse electrical energy what is the chmical composition of the material how it was possible to be prepared laboratory
CR4 Admin - email removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
i will be grateful for help
Re: Relpacement of Hydrazin Material
10/17/2010 1:16 PM
I'd ask a real chemical engineer if I were you. Or, the supplier of your chemicals.
Or, do some independent research, instead of asking strangers to do your work for you.
Also, it is unwise to publish your address. It will be erased by Admin.
10/17/2010 1:39 PM
Although it's heavily implied that you shouldn't post your email (the potential spam could be atrocious), it's often times not deleted like phone numbers are. Of course, I'm not sure why anyone would want to post their emails with all the people advertising round here sometimes.
The first law of thermodynamics is you do NOT talk about thermodynamics.
10/17/2010 1:48 PM
Hello Guest,
Before I get started here, I should disclaim that 75%+ of this information just came from combing through Google entries and papers written through manufacturers of the agents. A little poking around never hurts
As you probably know, as a chem. eng., Hydrazin(+e) is highly toxic and dangerously unstable, and is usually handled while in solution for safety reasons. For a while, most manufacturers utilized this as a fouling and corrosion inhibator, but after the introduction oft he more efficient and safer Helamin, a great number switched to using that substance instead.
Helamin does not significantly decompose even at high temperature and pressure employed in the modern sub-critical -water power-plant boilers. Helamin treatment can be successfully employed in steam generators, warm and hot water piping systems, superheaters, as well as cooling circuits to mitigate some of the difficult problems of the corrosion and fouling. However, cation conductivity of water tends to increase with the use of Helamin, but that sounds like it's something you want?
Anyways, here's a very interesting .pdf on the subject. Give it a skim through and you'll be much more knowledgeable for the experience (probably).
http://www.ppchem.net/free/ppchem-free-9-2004-2.pdf
