Previous in Forum: Voltage Change   Next in Forum: Power Factor of Induction Generator
Motor Testing
10/18/2010 9:34 AM
Can any one help me to give some reply of the following question. If a motor is burn out how will i know this? i.e. by which method should I follow to be confirmed or which instruments or apparatus should I use to detect this problem?
Re: motor testing
10/18/2010 9:38 AM
Look at it. Is the shaft going round and round when the motor is energized?
Good Answers: 181
Re: Motor Testing
10/18/2010 8:28 PM
The first thing you'll probably notice with a motor burn out is the smell, it's horrible!
After that you will need to do IR & CR tests.
Register to Reply 2 comments
