Previous in Forum: Power Factor Limit on Old Transformers   Next in Forum: Ground Fault on Fire Alarm Panel
transformer
10/20/2010 9:41 AM
does 11 KV/415 V 500 kVA transformer require buzholzh relay tripping. if not how do protect it against oil surge and gas formations.
Good Answers: 131
Re: transformer
10/20/2010 10:00 AM
No it doesn't. If you want it, you can have it but it costs and adds to the complexity of the transformer (more things to maintain).
Transformers this small are commodity items - relatively inexpensive and commonly available. The technology is quire mature and reliability is good. Buchholz relaying is found more commonly on larger units where down-time is costly, as well as the cost and availability of a replacement is more difficult. On these larger units the faster and more sensitive tripping may allow the unit to be repaired rather than thrown away, but on a 500kVA if it fails, you buy a replacement.
Periodic (annual) dissolved gas analysis (DGA) will give you enough data and history to plan for an orderly outage for investigation and repairs if gases increase. A fault will should trip your other protection such as overcurrent and differential (if you have it).
Good Answers: 170
Re: transformer
10/21/2010 9:18 AM
Vide Indian Electricity Rules, 1956, Rule No. 64A Sub-Rule 2 (c):
64A. Additional provisions for use of energy at high and extra-high voltage.-
The following additional provisions shall be observed where energy at high or extra-high voltage is supplied, converted, transferred or used, namely:-
(2) Protection – All systems and circuits shall be so protected as to automatically disconnect the supply under abnormal conditions.
The following protection shall be provided namely:-
[(c) Gas pressure type and winding and oil temperature protection to give alarm and tripping shall be provided on all transformers of ratings 1000 KVA and above;]
But, it is prudent to provide Buch Holz Protection for a 500kVA Transformer, considering the repair & dwontime costs.
Register to Reply 2 comments
