Previous in Forum: Shafts   Next in Forum: Plastic Injection Moulding
Hard Chroming Thickness on Hydraulic Cylinder Push Rod
10/20/2010 2:51 PM
All you hard chromers and hydraulic cylinder manufacturers out there
What is the standard or recommended thickness of hard chroming on say a push rod shaft of finished diameter 75mm,and length 900mm
What are the criteria for choosing that thickness.
I am talking of Material EN 19 condition T, which is induction hardened before hard chroming
Mike K
Joburg South Africa
Re: Hard Chroming Thickness on Hydraulic Cylinder Push Rod
10/20/2010 7:44 PM
I don't know. Ask one of these guys from Finishing.com:
some shops that offer hard chrome plating.
10/21/2010 6:27 AM
I had used 15 micron thickness for plating. To ensure the correct adherence and non inclusion of impurities and adequate cleaning grind it by 5 microns. These allowances are to be considered while initial machining.Use of self wearing green wheels for grinding is recommended.
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
10/24/2010 6:15 AM
Standard manufacturer recomends 30 to 50 micron Cr plating for standard cylinders. It depends on the environment conditions.
Anonymous Poster (1); kirannawathe (1); lyn (1)
