Previous in Forum: Inverter Air-Conditioners   Next in Forum: Welding a Plain End Fitting into Socket Weld Fitting
Tire Protection System
10/20/2010 4:02 PM
is it good to install the tyre protective chain in dumpers and wheel loaders
if it is good wat r the benefits we will get from that and also i wanna know tat wat will be cost of a tyre protection chain if we implement in a dumper or wheel loader and how much will be the life of that chain
Good Answers: 299
Re: tyre protection system
10/20/2010 5:19 PM
I am reminded of Jābir ibn Hayyān, considered by some as the father of chemistry.
His writings of chemistry and alchemy were extremely difficult to read or follow, often including symbols and phrases that made sense to no one but himself.
That being said: What, dear Guest, is a tyre protective chain? Are you perhaps asking about tyre Traction chains?
10/20/2010 6:22 PM
This may be what he means:
Benefit of using TIRESMIL tire protection chains
TIRESMIL tire protection chain is designed to save your money, it has been proven to be a high performance and most cost effective option to expensive European tire protection chain makers.
We believe that you will find what the TIRESMIL tire protection chain is worth using, it will brings you a substantial saving if you use it.
I haven't needed them on my pickup.
Good Answers: 299
10/21/2010 9:18 AM
You may well be correct: I have never seen those. In fact, I agree, and vote GA.
I can see the value of these in very a rough service machine...
10/21/2010 9:25 AM
Chain mail for your tyres.
I hope that cat notices that this "colonial" has used the "limey" spelling of tire.
Good Answers: 181
Re: Tire Protection System
10/20/2010 11:13 PM
Consult the tyre manufacturer. Some types of tyre tread will be shredded by chains while others benefit from them.
As to cost, it's up to you to look around.
Good Answers: 181
10/21/2010 11:04 AM
If you look at the picture in doorman's post, that tyre will get shredded in dry conditions.
Now look at the picture in lynlynch's post they are smooth profile, chains suit them.
One other problem comes in to the equation, given the speed off modern dump trucks is the risk of throwing a chain. There's been more than one life lost through a chain failing and going though the cab of the following dump truck.
Doorman (2); lyn (2); TonyS (2)
You might be interested in: Leaf Chain, Plastic and Metal Chain, Conveyor Chain
