Previous in Forum: Electro Active Polymers   Next in Forum: How to Neutralize Bleach?
Epoxy Resin for Glass Fiber Applications
10/22/2010 7:06 AM
Hello, can anyone help me with synthesis of epoxy resin which is used with glass fibers in composites??? what are raw materials, process and equipments etc.?
Re: epoxy resin for glass fiber applications
10/22/2010 7:14 AM
You don't need much, huh?
Try starting with google.
Re: Epoxy Resin for Glass Fiber Applications
10/22/2010 8:51 AM
Either hire a chemist or go to the hardware store and buy some.
"raw materials, process and equipments etc." are as varied as the types of epoxy.
And, what makes you think you need epoxy? Most people use polyester resin when making glass layups.
10/22/2010 11:23 AM
LOL, I am a chemist! not so good one.
10/22/2010 11:39 AM
The equipment required to produce epoxy resins is VERY expensive. The chemicals are noxious and the reactions must be closely controlled.
To get an idea of the reactions involved, you might want to perform "the nylon rope trick". Following the instructions, you will actually produce polyamide resin. This is not suitable for glass cloth impregnation, but is an interesting experiment to perform.
Good luck.
Polymerization of Nylon 6 and Nylon 6,10
Register to Reply 4 comments
Abdul Rauf (1); kramarat (1); lyn (2)
