Previous in Forum: Types of Drill Bit   Next in Forum: External and Internal Bicycles Hybrid Gear
Conversion of Sound Power to Sound Pressure Level
10/23/2010 3:55 AM
I need the formula
Re: conversion of sound power to sound pressure level
10/23/2010 4:34 AM
I don't think there is one.
As far as I know SPL needs actually measuring, ideally using a dummy head (yes seriously) as it is dependant on the accoustics of the environment.
10/23/2010 8:47 AM
Depending on the test procedure and what you are actually trying to measure, you might use a device such as the one below, as suggested by Del.
B&K 4128 HATS - Head and Torso Simulator
For actual sound measurements at the source of the noise a sound intensity probe is used.
This site gives an excellent presentation on the math of sound.
Sound Power, Intensity and Pressure
Acoustics in an extremely complicated field.
10/23/2010 10:47 AM
At last a picture of someone sensible to talk to
10/23/2010 10:52 AM
They never talk back, and for variety, you can change the ears.
Unfortunately they are very expensive.
Good Answers: 67
Re: Conversion of Sound Power to Sound Pressure Level
10/30/2010 7:02 AM
Sound Power(W)/ Area(m2) = Sound Pressure(Pa) x Particle Velocity(m/s)
Sound Level (dB) = 10log(base10) [Sound power x 10^12]
8
lyn (2); pritam (1); user-deleted-1105 (2)
