we were connecting a plating rcetifier unit to a plating basin while the rectifier input is 380 volt three phase and the chemist required 1.2 DC volt for his process and we gave him the required voltage through the regulator installed in the unit but the plating was too bad and it becam very good and acceptable to the chemist when we switched off one phase of the input AC voltage ,need to have an explaination because the unit was working properly only with two phase input.
