Previous in Forum: Un-Gluing Aquarium Glass   Next in Forum: Yahoo Mail Login Backgound Ads
Sharp Microwave
10/27/2010 12:41 AM
An egg was put in the microwave, it exploded forcing open the door and blowing the fuse. replaced fuse and when door is open fan come on and turntable operates. changed door switch to no avail. otherwise there is no problem with operation. is there another switch i should be trying to change?
Good Answers: 141
Re: Sharp Microwave
10/27/2010 1:26 AM
Did you check if the switch actuator is not bent and acts properly? I have met also microwaves with multiple switches. Maybe you've forgotten one? On my latest visit to the bush I recovered 3 pieces out of one.
Plenty of room here
Re: Sharp Microwave
10/27/2010 2:20 AM
yes, the switch is working, but i dont have a schematic, so not sure where the next interlock switch is located in line.
Good Answers: 141
Re: Sharp Microwave
10/27/2010 3:13 AM
Screwdriver, and explore inside. Check for a plastic molded frame with small micro switches in it. See also that the door makes good contact(s). The more simple and cheap, the more switches.
Plenty of room here
Re: Sharp Microwave
10/27/2010 6:55 AM
It's possible that wet egg blew through the vents inside and it's acting as a conductor somewhere between contacts.
Good Answers: 60
Re: Sharp Microwave
10/27/2010 11:08 AM
last time i dismantled a micro there was three switches on the door but you need to be inside to see them.
they are the magnetron safetys
you need to check these.
dvmdsc (2); kramarat (1); lorconv (1); peterg7lyq (1)
You might be interested in: Door Operators, Fuse Holders, Door Stays and Lid Stays
